HI All,
I installed on VM Machine (111.111.111.14) Windows 7 64bit a Thingworx 8.0.3.-b52 and I created a Thing 'TestRemoteThing' using ThinTemplate RemoteThing.
I created another VM Machine (111.111.111.11) Windows 7 64bit where I installed Eclipse and I imported a package Java SDK 221-Java-SDK-6-0-4-595.zip (dowbloaded from PTC Market place)
I'm using the documentation from http://support.ptc.com/help/thingworx_hc/thingworx_edge/index.html.
I Run SimpleClient.java using :
- config.setUri("wss://111.111.111.14:443/Thingworx/WS");
- config.setAppKey("1146b538-3ad5-4977-8679-3f6bf2b55081"); application-key generate on Thingworx
but the connection failed.
Is it necessary a setting on Thingworx platform ?
I run a test WebServices.html and it answer
WebSocket Test
ERROR: undefined
DISCONNECT
What is the next check I have to do?
Do I have to install any software on the PC on which Thingworx is installed?
Many Thanks
BR
Dimitri
Hi All,
I used the following step :
1) stop tomcat
2) create a new directory keystore on c:\<tomcat_pathname>
3) create a self-signed certificate with java keytool running the following command
c:\<path_java>\jre\bin\Keytool -genkey -alias tomcat -keyalg RSA -keystore c:\<tomcat-folder>\keystore\.keystore
using password "changeit"
4) add the follwing row in C:\<tomcat_pathname>\conf\server.xml
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol"
maxThreads="150" SSLEnabled="true">
<SSLHostConfig>
<Certificate certificateKeystoreFile="keystore/.keystore" type="RSA" />
</SSLHostConfig>
</Connector>
5) start Tomcat
6) using IE with url https:/7localhost:8443, click on "Continue to this website (not recmmended)
By
Dimitri
I create the keystore file into <pathname_tomcar>\kestore\.keystore using the command
c:\<path_java>\jre\bin\Keytool -genkey -alias tomcat -keyalg RSA -keystore <tomcat-folder>\keystore\.keystore
Hi @dbologna I would start checking details in following order
- Are all the pre-requisites met as described in the Setting Up to Run Sample Applications
- Can those two VMs interact with each other? e.g. is VM1 able to ping VM2 and vice versa , ensure connection is somehow not blocked over the network or
- To which user account does this app key belong to? I.e. does it have sufficient access rights assigned to it
- Start debugging your code from the Eclipse IDE together with logs on trace to try and get more specific error stack
If you are done with the pre-requisites I don't think there's any separate requirement to install any specific software on ThingWorx server
My answers (bold) at your/her questions ?
- Are all the pre-requisites met as described in the Setting Up to Run Sample Applications.
I’m not using Glade but I’m using Eclipse (https://developer.thingworx.com/resources/guides/thingworx-java-sdk-setup-guide)
VM1 ping VM2 and vice versa . The firewall on both VM are disabled.
The application key create in Thingworx Platform have ‘Administrator’ as ‘User Name Reference’.
If I’m using config.setUri(“ws://111.111.111.14:80/Thingworx/WS”); the connection works.
If I’m using config.setUri(“wss://111.111.111.14:8443/Thingworx/WS”); not work because the tomcat not support SSL/TLS protocol.
I have enabled this protocol by performing the following steps (using the support documentations) :
keytool -genkey -alias tomcat -keystore tomcat.keystore -keyalg RSA
<Connector port="8443" protocol="org.apache.coyote.http11.Http11NioProtocol" SSLEnabled="true"
maxThreads="150" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS"
enableLookups="false" keystoreFile="conf/tomcat.keystore" keystorePass=”changeit!" />
57 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["https-jsse-nio-8443"]
01-Mar-2018 22:16:01.770 SEVERE [main] org.apache.catalina.util.LifecycleBase.handleSubClassException Failed to initialize component [Connector[HTTP/1.1-8443]]
org.apache.catalina.LifecycleException: Protocol handler initialization failed
I’m using Tomcat 9.0.5 and java 1.8.0_144.
Every suggestion is well received.
BR
Dimitri
Mant thanks,
I found solution for the following version of Tomcat 8.5.23, 8.5.28 and 9.0.5.
BR
Dimitri
Hi All,
1) stop tomcat
<SSLHostConfig>
</SSLHostConfig>
</Connector>
5) start Tomcat
By
Dimitri
