ThingWorx with InfluxDB
wshih
6-Contributor
Hi all:
Does anyone use InfluxDB to record history data?
I try to use "PostText()" And "PostJSON()"
But I can't get right response.
Here is my script:
QueryDB
var params = {
  url: "http://" + me.host + ":" + me.port + "/query?db=" + p_database,
  contentType: "application/x-www-form-urlencoded",
content: "q:SELECT * FROM sensor;", timeout: 10, username: me.user, password: me.password }; var result = Resources["ContentLoaderFunctions"].PostText(params);
InsertDB
var params = {
content: "sensor,type=123,way=222 value={"p_water":0.0,"p_power_value":-1}", timeout: 10, username: me.user, password: me.password }; var result = Resources["ContentLoaderFunctions"].PostText(params);
Usually I get timeout, but it is successful to execute on the Postman.
PaiChung
22-Sapphire I
(To:wshih)
Try with everything fully hardcoded and see if you get the same result or not (don't substitute in from properties and variables) This at least will eliminate one cause.
Also you can try setting the application log to trace for a while and fire the request and see if there is any extra info to figure out what might be wrong.
