Hello.
I'm trying to connect to my localhost:8080/Thingworx Composer.
I'm executing a tutorial jar file.
The Error message I'm getting is this.
java -Duser.country=US -Duser.language=en -jar TruckSimulator.jar 15:00:40.405 [main] INFO c.t.c.c.p.ClientMessageProcessor - Created new ClientMessageProcessor [minPoolSize: 4, maxPoolSize: 10, maxThreadLife: 10000, maxQueueSize: 1000] Starting the stuff URL: ws://http://127.0.0.1:8080/Thingworx/WS AppKey: bde92937-8a45-4089-ae41-5dde64482dfb 15:00:40.460 [main] DEBUG i.n.u.i.l.InternalLoggerFactory - Using SLF4J as the default logging framework 15:00:40.462 [main] DEBUG i.n.c.MultithreadEventLoopGroup - -Dio.netty.eventLoopThreads: 16 15:00:40.468 [main] DEBUG i.n.util.internal.PlatformDependent0 - sun.nio.ch.DirectBuffer.cleaner(): unavailable WARNING: An illegal reflective access operation has occurred WARNING: Illegal reflective access by io.netty.util.internal.PlatformDependent0 (file:/C:/Users/Ryong/Documents/MicroServer_Java/TruckSimulator.jar) to field java.nio.Buffer.address WARNING: Please consider reporting this to the maintainers of io.netty.util.internal.PlatformDependent0 WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations WARNING: All illegal access operations will be denied in a future release 15:00:40.470 [main] DEBUG i.n.util.internal.PlatformDependent0 - java.nio.Buffer.address: unavailable 15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - Platform: Windows 15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - Java version: 8 15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noUnsafe: false 15:00:40.471 [main] DEBUG i.n.util.internal.PlatformDependent - sun.misc.Unsafe: unavailable 15:00:40.483 [main] DEBUG i.n.util.internal.PlatformDependent - maxDirectMemory: 4265607168 bytes (maybe) 15:00:40.483 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noJavassist: false 15:00:40.484 [main] DEBUG i.n.util.internal.PlatformDependent - Javassist: unavailable 15:00:40.484 [main] DEBUG i.n.util.internal.PlatformDependent - You don't have Javassist in your class path or you don't have enough permission to load dynamically generated classes. Please check the configuration for better performance. 15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.tmpdir: C:\Users\Ryong\AppData\Local\Temp (java.io.tmpdir) 15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.bitMode: 64 (sun.arch.data.model) 15:00:40.485 [main] DEBUG i.n.util.internal.PlatformDependent - -Dio.netty.noPreferDirect: true 15:00:40.485 [main] INFO i.n.util.internal.PlatformDependent - Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system unstability. 15:00:40.495 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.noKeySetOptimization: false 15:00:40.495 [main] DEBUG io.netty.channel.nio.NioEventLoop - -Dio.netty.selectorAutoRebuildThreshold: 512 15:00:40.715 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numHeapArenas: 8 15:00:40.715 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.numDirectArenas: 8 15:00:40.717 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.pageSize: 8192 15:00:40.721 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxOrder: 11 15:00:40.722 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.chunkSize: 16777216 15:00:40.722 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.tinyCacheSize: 512 15:00:40.725 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.smallCacheSize: 256 15:00:40.726 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.normalCacheSize: 64 15:00:40.730 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.maxCachedBufferCapacity: 32768 15:00:40.731 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheTrimInterval: 8192 15:00:40.731 [main] DEBUG i.n.buffer.PooledByteBufAllocator - -Dio.netty.allocator.cacheCleanupInterval: 5000 ms 15:00:40.738 [main] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - Initializing CommunicationEndpoint Connection Monitor... 15:00:40.742 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.m.CommunicationEndpointMonitorTask - CommunicationEndpoint Monitor - checking for disconnected endpoints 15:00:40.743 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint not connected [name: EP_0, id: 0]. Attempting [re]connect... 15:00:40.743 [Client-EndpointMonitor-1] DEBUG c.t.c.c.e.ClientCommunicationEndpoint - Clearing endpoint authentication data [id: 0] 15:00:40.744 [Client-EndpointMonitor-1] INFO c.t.c.c.e.ClientCommunicationEndpoint - Needed to refill connections on client endpoint [id: 0] : [active: 0, max: 1] 15:00:43.024 [Client-EndpointMonitor-1] ERROR c.t.c.c.e.ClientCommunicationEndpoint - Refilling connections on [endpoint 0, uri: ws://http://127.0.0.1:8080/Thingworx/WS] failed : null 15:00:43.024 [Client-EndpointMonitor-1] INFO c.t.c.c.e.m.CommunicationEndpointMonitorTask - Endpoint reconnection was unsuccessful [name: EP_0, id: 0]
I've configured my TrainingConfig.json file like this.
"ServerLocation": "http://127.0.0.1",
"Port": 8080,
"AppKey": "xxxx-xxx-xxx-xxxxx(my app key)",
"Security": false,
"RemoteRepo": "/ThingworxRemoteRepository"
Can someone tell me how to solve this problem?
Thanks.
