Thingworx Flow of execution Issue
MA8731174
Scenario:
I have three mashups in total
1) Main Mashup
2) Popup Mashup 1
3) Popup Mashup 2
On Main Mashup I am navigating to these above two popup mashups. I have opened Popup Mashup 1 then Popup Mashup 2 means The popup mashup 1 was still opened when i open popup mashup 2 then i close the mashup 2 and onclose of this mashup i evlautate this EXPRESSION which returns Output=true
I send this output = true through the mashup parameters in popup mashup 1 there i have event router and i want to close this popup mashup 1 and i have bind the closeifpopup event with changed event of this event router as below you can see.
but it does not work when i close the popup mashup 2.
The popup mashup 1 remains opened BUT when i close the popup mashup 1 manually and then open it right after then it closes automatically means now logic is working. Now if i open it again it gets close.
Any one has an idea that how it could be resolved? I have tried Autoevaluate and fire on first output both options but results are same. What can be done any idea?
@Rocko  Can you please test this scenario also at your side. I think for you the results would be same too.
