hello,
i would like to know is their any way by which we can choose learners other then the 6 learners provided by the thingworx for creating Predcition model ,if yes what is the way for it is their any document avaiable for it.please suggest if any.
Hi Amar,
Do you mean you want to add more learners than the ones available within ThingWorx Analytics or you would like to reconfigure the learning techniques but using the same learning algorithms available within ThingWorx Analytics ?
Best Regards,
Amine
Hello Amine ,
I meant like i want to add more learners than the ones available within thingworx analytics,if yes please share any document for the same.
Regards ,
Amar
Hello Amar,
Actually, the learning algorithms that you find in the ThingWorx Analytics Builder are the ones that are preprogrammed within the Analytics Server API hence it is not possible as of today for the user to add other learning Algorithms than the ones provided out of the Box.
Best Regards,
Amine
Hello Amine ,
Thanks for replying.
You said the learners which are available are preprogrammed with the analytics server API,so my question is being a developer is their any way of programming external learners to the analytics server API . As Thingworx has provided various extension SDK or toolkit ,can we use one of them for for adding new learner
Warm Regards,
Amar
Hello Amar,
ThingWorx Analytics is not extensible by End Users as of today. This means that you could not program your own Learners and add them to ThingWorx Analytics Server. The SDKs that you mentioned are related to the ThingWorx Platform which is indeed extensible and which should not be confused with ThingWorx Analytics.
I hope this answers your question
Best Regards,
Amine
Yes ,
Thank you for the information.
I had one more question that, if we cannot add more learners in the Thingworx analytics, we can use external analytics tool which is widely available, how can we use them and integrate those to thingworx core.
