Hi. I've an issue with initializing Thingworx with Tomcat
I had the Thingworx platform working for 7.0 with Tomcat but for no apparent reason to me it stopped working. Basically every time i click start on Tomcat after a few seconds it automatically stops. I've looked at the logs for tomcat and it never actually finishes deploying Thingworx.war. I've tried reinstalling everything again, Even deleted everything (including a Windows 10 refresh install) and started with 7.1 but I still have the same issue. I've tried deploying a standard java web app and it works flawlessly but everytime I add Thingworx.war to the webapps in Tomcat it just stops working. I've also set the permissions for full control over all the thingworx folders as well as tomcat to no avail.
Here is the log entry for my last try:
2016-05-23 15:25:26 Commons Daemon procrun stderr initialized
23-May-2016 15:25:27.079 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.35
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: May 11 2016 21:57:08 UTC
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.35.0
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 10
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 10.0
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_91
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_91-b14
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
23-May-2016 15:25:27.080 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseNUMA
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseConcMarkSweepGC
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms5g
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx5g
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
23-May-2016 15:25:27.081 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\ProgramData\Oracle\Java\javapath;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Skype\Phone\;C:\Program Files\Git\cmd;C:\Program Files\PostgreSQL\9.5\bin;.
23-May-2016 15:25:27.177 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
23-May-2016 15:25:27.225 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
23-May-2016 15:25:27.227 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
23-May-2016 15:25:27.228 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
23-May-2016 15:25:27.229 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 396 ms
23-May-2016 15:25:27.246 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
23-May-2016 15:25:27.246 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.35
23-May-2016 15:25:27.262 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
23-May-2016 15:25:29.217 INFO [localhost-startStop-1] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
Can anyone please tell me if I'm missing something?
Thank you in advance
Francisco, this would likely point to changes in the Postgres configuration. Can you re-verify your Postgres install? Mainly from a configuration perspective, to check if the platform-settings.json file in \ThingworxPlatform has the right url and if the username/ password matches.
Francisco, can you post your Application log from ThingworxStorage/ logs as well? On a side note, you might want to reduce your xms value from 5g to 256m or 512m, because you don't want the JVM to always start with and run at 5 gigs.
I had the 5g as seen in the installation of 7.1. I know it is too much to start but I was trying everything by the book
Looking at the Application Log I now realize there is some place where the ownership is not being properly set. I've tried the ThingworxPlatform folder as well as tomcat. I'll keep looking into it see if I missed something I'll get back to you. Thank you for your quick reply.
I'll leave here the log anyway in case you spot something else:
2016-05-23 17:00:25.627+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-05-23 17:00:25.628+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 7
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 1
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 1
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b24
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 910
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Windows 10
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 10.0
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 8
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: UTF-8
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2016-05-23 17:00:25.629+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_91
2016-05-23 17:00:25.630+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: C:\Program Files\Java\jre1.8.0_91
2016-05-23 17:00:25.630+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 247 (MB)
2016-05-23 17:00:25.630+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2016-05-23 17:00:25.630+0100 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2016-05-23 17:00:25.889+0100 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] HA mode not enabled. Initializing and starting in standalone mode.
2016-05-23 17:00:25.889+0100 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Name = ThingworxPersistenceProvider
2016-05-23 17:00:25.889+0100 [L: INFO] [O: c.t.s.ThingWorxPersistenceHandler] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default Persistence Provider Package Name = PostgresPersistenceProviderPackage
2016-05-23 17:00:25.899+0100 [L: INFO] [O: c.t.p.p.PostgresDatasource] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Reading configuration from configTableCol
2016-05-23 17:00:26.098+0100 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Managers...INITIALIZED
2016-05-23 17:00:26.102+0100 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Database initialization started...
2016-05-23 17:00:26.356+0100 [L: INFO] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] System ownership locking started...
2016-05-23 17:00:26.368+0100 [L: ERROR] [O: c.t.p.p.PostgresDocumentModelDriver$SystemDocumentModelInformation] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Platform being shut down because System Ownership can not be acquired.
2016-05-23 17:00:26.369+0100 [L: WARN] [O: c.t.s.ThingWorxServer] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Shutting down the Platform.
That was exactly what it was, thank you very much for your help and patience.
No problem, glad to see it resolved quickly!
Spandana here
Even i am unable to deploy thingworx.war file in tomcat8.0
Below are My log files
catalina.2017-03-01
01-Mar-2017 12:03:19.399 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.41
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jan 18 2017 22:19:39 UTC
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.41.0
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_121
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13
01-Mar-2017 12:03:19.500 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
01-Mar-2017 12:03:19.501 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
01-Mar-2017 12:03:19.502 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
01-Mar-2017 12:03:19.502 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\windows\Sun\Java\bin;C:\windows\system32;C:\windows;C:\ProgramData\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft Application Virtualization Client;C:\Users\bavithraa.m\AppData\Local\Programs\Git\cmd;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\ManagementStudio\;C:\Program Files\Citrix\System32\;C:\Program Files\Citrix\ICAService\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files\Git\cmd;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;;.
01-Mar-2017 12:03:20.369 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
01-Mar-2017 12:03:20.705 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
01-Mar-2017 12:03:20.753 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
01-Mar-2017 12:03:20.753 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
01-Mar-2017 12:03:20.753 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 3050 ms
01-Mar-2017 12:03:20.848 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
01-Mar-2017 12:03:20.848 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.41
01-Mar-2017 12:03:20.872 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
01-Mar-2017 12:03:22.110 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 1,239 ms
01-Mar-2017 12:03:22.110 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
01-Mar-2017 12:03:22.223 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 113 ms
01-Mar-2017 12:03:22.223 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
01-Mar-2017 12:03:22.285 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 62 ms
01-Mar-2017 12:03:22.332 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
01-Mar-2017 12:03:22.348 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
01-Mar-2017 12:03:22.379 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 1614 ms
01-Mar-2017 15:22:01.259 INFO [main] org.apache.catalina.core.StandardServer.await A valid shutdown command was received via the shutdown port. Stopping the Server instance.
01-Mar-2017 15:22:01.275 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
01-Mar-2017 15:22:01.449 INFO [main] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"]
01-Mar-2017 15:22:01.511 INFO [main] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina
01-Mar-2017 15:22:01.745 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
01-Mar-2017 15:22:01.870 INFO [main] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"]
01-Mar-2017 15:22:01.963 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["http-nio-8080"]
01-Mar-2017 15:22:01.963 INFO [main] org.apache.coyote.AbstractProtocol.destroy Destroying ProtocolHandler ["ajp-nio-8009"]
ApplicationLog.log file:-
2017-03-01 15:35:11.067+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.069+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ThingWorx Version Information
2017-03-01 15:35:11.069+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.069+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] majorVersion = 7
2017-03-01 15:35:11.069+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] minorVersion = 3
2017-03-01 15:35:11.069+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] revision = 0
2017-03-01 15:35:11.070+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] build = b51
2017-03-01 15:35:11.070+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] schemaVersion = 931
2017-03-01 15:35:11.070+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.088+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.089+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ThingWorx System Environment Settings
2017-03-01 15:35:11.089+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.089+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS: Windows 7
2017-03-01 15:35:11.095+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS arch: amd64
2017-03-01 15:35:11.095+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] OS version: 6.1
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Total Processors: 2
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Default encoding: windows-1252
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA vendor: Oracle Corporation
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA version: 1.8.0_121
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JAVA install location: C:\Program Files\Java\jdk1.8.0_121\jre
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] JVM Max Memory: 885 (MB)
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] ========================================
2017-03-01 15:35:11.106+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] WebApp starting...
2017-03-01 15:35:11.106+0530 [L: WARN] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] Please note. Default character is set to Cp1252. It should be [UTF-8]. Please use the VM argument [-Dfile.encoding=UTF-8] in your application server startup script
2017-03-01 15:35:45.709+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2]
2017-03-01 15:35:45.709+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-2] *** Web Application STATE is being set to ERROR! ***
2017-03-01 15:39:46.344+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-9] WebApp stopping:
2017-03-01 15:39:46.345+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-9] ThingWorx Web Application STATE is in ERROR, so normal shutdown logic may fail!
2017-03-01 15:39:47.029+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: http-nio-8080-exec-9] Error getting ApplicationContext: {}null
2017-03-01 15:46:15.826+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-03-01 15:46:15.826+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx Version Information
2017-03-01 15:46:15.826+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] majorVersion = 7
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] minorVersion = 3
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] revision = 0
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] build = b51
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] schemaVersion = 931
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ThingWorx System Environment Settings
2017-03-01 15:46:15.841+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS: Windows 7
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS arch: amd64
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] OS version: 6.1
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Total Processors: 2
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Default encoding: windows-1252
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA vendor: Oracle Corporation
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA version: 1.8.0_121
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JAVA install location: C:\Program Files\Java\jdk1.8.0_121\jre
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] JVM Max Memory: 885 (MB)
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] ========================================
2017-03-01 15:46:15.857+0530 [L: INFO] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] WebApp starting...
2017-03-01 15:46:15.857+0530 [L: WARN] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] Please note. Default character is set to Cp1252. It should be [UTF-8]. Please use the VM argument [-Dfile.encoding=UTF-8] in your application server startup script
2017-03-01 15:46:45.471+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1]
2017-03-01 15:46:45.471+0530 [L: ERROR] [O: c.t.s.ThingWorxBootstrapper] [I: ] [U: SuperUser] [S: ] [T: localhost-startStop-1] *** Web Application STATE is being set to ERROR! ***
Please help to resolver this issue
Hi Spandana
From teh error it seems there is an issue with the character set.
Could you double check that the UTF-8 character set is in place as per the installation guide ?
See http://support.ptc.com/WCMS/files/172180/en/Installing_ThingWorx_7.3_1.pdf, you can search for UTF-8 in this file, you can find the relevant setting depending on your platform.
Hope this helps
Kind regards
Christophe
Thanks for your quick reply,
I have tried modifying UTF-8 character set settings as you mentioned but problem still persist. Unable to deploy thinworx.war file in tomcat. here i am providing my log file.
catalina.2017-03-02
02-Mar-2017 12:10:18.194 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.41
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jan 18 2017 22:19:39 UTC
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.41.0
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_121
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
02-Mar-2017 12:10:18.287 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\windows\Sun\Java\bin;C:\windows\system32;C:\windows;C:\ProgramData\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft Application Virtualization Client;C:\Users\bavithraa.m\AppData\Local\Programs\Git\cmd;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\ManagementStudio\;C:\Program Files\Citrix\System32\;C:\Program Files\Citrix\ICAService\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files\Git\cmd;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;;.
02-Mar-2017 12:10:19.130 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:10:19.769 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Mar-2017 12:10:19.769 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:10:19.769 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 3267 ms
02-Mar-2017 12:10:19.832 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
02-Mar-2017 12:10:19.832 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.41
02-Mar-2017 12:10:19.847 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
02-Mar-2017 12:10:20.502 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 655 ms
02-Mar-2017 12:10:20.502 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
02-Mar-2017 12:10:20.565 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 63 ms
02-Mar-2017 12:10:20.565 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
02-Mar-2017 12:10:20.596 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 31 ms
02-Mar-2017 12:10:20.612 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:10:20.643 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:10:20.643 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 873 ms
02-Mar-2017 12:15:55.699 INFO [Thread-6] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:15:55.793 INFO [Thread-6] org.apache.coyote.AbstractProtocol.pause Pausing ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:15:55.855 INFO [Thread-6] org.apache.catalina.core.StandardService.stopInternal Stopping service Catalina
02-Mar-2017 12:15:56.058 INFO [Thread-6] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:15:56.136 INFO [Thread-6] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:16:15.813 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.41
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Jan 18 2017 22:19:39 UTC
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.41.0
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows 7
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jre1.8.0_121
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_121-b13
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dserver -Dd64
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -XX:+UseG1GC
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dfile.encoding=UTF-8
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
02-Mar-2017 12:16:15.828 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\windows\Sun\Java\bin;C:\windows\system32;C:\windows;C:\ProgramData\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Microsoft Application Virtualization Client;C:\Users\bavithraa.m\AppData\Local\Programs\Git\cmd;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\ManagementStudio\;C:\Program Files\Citrix\System32\;C:\Program Files\Citrix\ICAService\;C:\Program Files\Microsoft SQL Server\Client SDK\ODBC\110\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\Tools\Binn\;C:\Program Files\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\120\Tools\Binn\ManagementStudio\;C:\Program Files (x86)\Microsoft SQL Server\120\DTS\Binn\;C:\Program Files\Git\cmd;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;;.
02-Mar-2017 12:16:16.156 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:16:16.345 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Mar-2017 12:16:16.345 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:16:16.361 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
02-Mar-2017 12:16:16.361 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 1100 ms
02-Mar-2017 12:16:16.408 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
02-Mar-2017 12:16:16.408 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.41
02-Mar-2017 12:16:16.423 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
02-Mar-2017 12:16:16.829 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 406 ms
02-Mar-2017 12:16:16.829 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
02-Mar-2017 12:16:16.930 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 101 ms
02-Mar-2017 12:16:16.931 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
02-Mar-2017 12:16:16.987 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 57 ms
02-Mar-2017 12:16:16.987 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
02-Mar-2017 12:16:17.018 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
02-Mar-2017 12:16:17.018 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 662 ms
Could you please provide your valid inputs to resolve this error.
Thanks& Regards
Spandhana
I am getting following Error while uploading thingworx.war file
The webpage at http://localhost:8080/manager/html/upload?org.apache.catalina.filters.CSRF_NONCE=0886FC9C4F01EF4F77F0BFEB8B1B3355might be temporarily down or it may have moved permanently to a new web address.
ERR_CONNECTION_ABORTED
Regards
Spandhana
Hi Spandhana
Your latest catalina.log shows a successful start of Tomcat, however there is no Thingworx application deployed, so most likely you do not have a thingworx.war under <Tomcat>/webapps.
I see above that you are having an error while attempting to upload the war file from the Tomcat manager UI, could you try to simply copy the file under <Tomcat>/webapps and restart Tomcat ?
If you still have issues, please provide catalina log and ThingWorx application.log file.
Christophe
Kirti here,
I have thingworx installed since 9 days.Today suddenly tomcat got stopped and when I tried to restart It is stopping over and over again.Below are my log files.
catalina.2017-04-18
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server version: Apache Tomcat/8.0.33
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server built: Mar 18 2016 20:31:49 UTC
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Server number: 8.0.33.0
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Name: Windows Server 2008 R2
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log OS Version: 6.1
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Architecture: amd64
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Java Home: C:\Program Files\Java\jdk1.8.0_112\jre
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Version: 1.8.0_112-b15
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log JVM Vendor: Oracle Corporation
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_BASE: C:\Program Files\Apache Software Foundation\Tomcat 8.0
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log CATALINA_HOME: C:\Program Files\Apache Software Foundation\Tomcat 8.0
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.home=C:\Program Files\Apache Software Foundation\Tomcat 8.0
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Dcatalina.base=C:\Program Files\Apache Software Foundation\Tomcat 8.0
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.endorsed.dirs=C:\Program Files\Apache Software Foundation\Tomcat 8.0\endorsed
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.io.tmpdir=C:\Program Files\Apache Software Foundation\Tomcat 8.0\temp
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Djava.util.logging.config.file=C:\Program Files\Apache Software Foundation\Tomcat 8.0\conf\logging.properties
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: exit
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xms128m
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.startup.VersionLoggerListener.log Command line argument: -Xmx256m
18-Apr-2017 11:21:47.048 INFO [main] org.apache.catalina.core.AprLifecycleListener.lifecycleEvent The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Apache Software Foundation\Tomcat 8.0\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\Ruby22\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\M1 Licensing;E:\Program Files (x86)\Proficy\Proficy Portal\webapps\infoAgentSrv\WEB-INF\bin;E:\Program Files (x86)\Proficy\Proficy Portal\webapps\infoAgentSrv\WEB-INF;C:\Program Files (x86)\Windows Kits\8.1\Windows Performance Toolkit\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Program Files (x86)\Proficy\Proficy CIMPLICITY\exe;E:\Program Files (x86)\Proficy\Proficy CIMPLICITY\exe;E:\Program Files (x86)\Proficy\Proficy CIMPLICITY\exe;C:\Windows\System32;C:\Windows;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files (x86)\Microsoft SQL Server\100\DTS\Binn\;C:\Program Files\cURL\bin;C:\Program Files\Cloud Foundry;C:\Program Files (x86)\Cloud Foundry;C:\Program Files\Java\jdk1.8.0_112\bin;C:\Windows\system32;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\PostgreSQL\9.4\bin;.
18-Apr-2017 11:21:48.187 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["http-nio-8080"]
18-Apr-2017 11:21:48.467 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
18-Apr-2017 11:21:48.467 INFO [main] org.apache.coyote.AbstractProtocol.init Initializing ProtocolHandler ["ajp-nio-8009"]
18-Apr-2017 11:21:48.467 INFO [main] org.apache.catalina.startup.Catalina.load Initialization processed in 2592 ms
18-Apr-2017 11:21:48.561 INFO [main] org.apache.catalina.core.StandardService.startInternal Starting service Catalina
18-Apr-2017 11:21:48.561 INFO [main] org.apache.catalina.core.StandardEngine.startInternal Starting Servlet Engine: Apache Tomcat/8.0.33
18-Apr-2017 11:21:48.639 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs
18-Apr-2017 11:21:48.998 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\docs has finished in 359 ms
18-Apr-2017 11:21:48.998 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager
18-Apr-2017 11:21:49.076 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\manager has finished in 78 ms
18-Apr-2017 11:21:49.076 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deploying web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT
18-Apr-2017 11:21:49.107 INFO [localhost-startStop-1] org.apache.catalina.startup.HostConfig.deployDirectory Deployment of web application directory C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\ROOT has finished in 31 ms
18-Apr-2017 11:21:49.107 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["http-nio-8080"]
18-Apr-2017 11:21:49.123 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler ["ajp-nio-8009"]
18-Apr-2017 11:21:49.123 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 644 ms
18-Apr-2017 11:31:29.712 INFO [localhost-startStop-2] org.apache.catalina.startup.HostConfig.deployWAR Deploying web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war
18-Apr-2017 11:32:09.928 INFO [localhost-startStop-2] org.apache.jasper.servlet.TldScanner.scanJars At least one JAR was scanned for TLDs yet contained no TLDs. Enable debug logging for this logger for a complete list of JARs that were scanned but no TLDs were found in them. Skipping unneeded JARs during scanning can improve startup time and JSP compilation time.
18-Apr-2017 11:32:22.009 INFO [localhost-startStop-2] org.apache.catalina.startup.HostConfig.deployWAR Deployment of web application archive C:\Program Files\Apache Software Foundation\Tomcat 8.0\webapps\Thingworx.war has finished in 52,297 ms
tomcat8-stderr.2017-04-27 file:-
org.apache.catalina.core.StandardServer await
SEVERE: StandardServer.await: create[localhost:8005]:
java.net.BindException: Address already in use: JVM_Bind
at java.net.DualStackPlainSocketImpl.bind0(Native Method)
at java.net.DualStackPlainSocketImpl.socketBind(DualStackPlainSocketImpl.java:106)
at java.net.AbstractPlainSocketImpl.bind(AbstractPlainSocketImpl.java:387)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:190)
at java.net.ServerSocket.bind(ServerSocket.java:375)
at java.net.ServerSocket.<init>(ServerSocket.java:237)
at org.apache.catalina.core.StandardServer.await(StandardServer.java:438)
at org.apache.catalina.startup.Catalina.await(Catalina.java:717)
at org.apache.catalina.startup.Catalina.start(Catalina.java:663)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:351)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:485)
Please help to resolve this issue.
Thanks ,
