Has anyone explored Update service in Windchill connector? I am having hard time finding out how to update an object in Windchill. What syntax would work for modification parameter. Any pointers..
var params = {
modification: undefined /* STRING */,
dataShape: undefined /* DATASHAPENAME */,
objects: undefined /* INFOTABLE */
// result: INFOTABLE dataShape: "undefined"
var result = me.Update(params);
Hi
If you use the executeTask service, you can create a Windchill task that takes parameters and updates an object accordingly. Your task should be written to perform the whole update process within a single transaction.
For passing the parameters in this case, you use the IEProperty datashape and create one row in the InfoTable for each parameter.
Regards
Ian
yes I got it working finally Ian. Thanks for replying. It was hit and trial to figure out the syntax.
i am trying to see what all possible with update service.
var params1 = {
modification: "REPLACE" /* STRING */,
dataShape: 'preeti-epmdoc1-datashape' /* DATASHAPENAME */,
objects: ufids /* INFOTABLE */
thx
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
