pshashipreetham
Sep 26, 2023 12:59 PM UTC
Hi @slangley
Thanks for the Follow-up, and Thanks, @nmutter @TanmeyTWX @VladimirRosu_116627, for all the replies. We have written the custom logic to record the User Active Status when a user opens the Landing Page.
Also, I have submitted the Idea:
A Option to Record the User last Active - PTC Community
Shashi Preetham || +91 8099838801 || shashi@psptechhub.com
Aug 31, 2023 9:02 AM UTC
Take a look this discussion - "Capture User Account Lockout Event": https://community.ptc.com/t5/ThingWorx-Developers/Capture-User-Account-Lockout-Event/td-p/642575
pshashipreetham
Sep 3, 2023 3:11 PM UTC
Hi @VladimirN ,
This is not what we are looking for, and we need the timestamp when the User last logged In.
Sep 4, 2023 7:16 AM UTC
Try this example:
"1. Retrieve User Login Info: You can use the UserEntity service `GetLoginHistory` to get the login history for a user. This service returns a result set that contains information about user logins.
2. Filter Login History: Once you have the login history, you can filter it to get the last logged-in timestamp. The login history returned by `GetLoginHistory` is ordered by timestamp, so you can simply retrieve the first entry.
Here's an example of how you can achieve this using the ThingWorx REST API:
GET /Thingworx/Things/UserEntity/Services/GetLoginHistory?name=<username>&appKey=<your_app_key>
Replace `<username>` with the username of the user you want to retrieve the login history for, and `<your_app_key>` with your ThingWorx application key.
This API call will return a JSON response containing the login history for the user. You can parse the response to extract the timestamp of the last login".
Sep 4, 2023 8:45 AM UTC
I am not sure if this works in the case you use the SSO authenticator, but each User has a property called "lastConnection", that you would see if you create a service where you reference any User administrator, in its available properties.
In my non-SSO environment, this works correctly:
result = Users["Administrator"].lastConnection;
pshashipreetham
Sep 4, 2023 1:28 PM UTC
Hi @VladimirRosu_116627,
Thanks for sharing the input. Based on it, what I found is:
  1. For Non-SSO Users: Users["Administrator"].lastConnection;
  2. For SSO Users: Users["Administrator"].GetLastModifiedDate();
But both ways, the Timestamp will reset when the Server is restarted.
Sep 4, 2023 2:42 PM UTC
Hi Shashi,
To achieve your requirement, you need to develop your own logic on top of what @VladimirRosu_116627 mentioned above. I had developed the exact User usage report for every user login. You could trigger a service on master load on every user login which will do an entry to a stream so that you can get all the historic login attempts and then prepare the report.
