Using PostgreSQL as the model data provider
ahamad
6-Contributor
I installed Thingworx using twxFoundationH2Trial-8.3.2-linux-x64-installer.run and I'm trying to make it use Postgresql as the model provider. I edited platform-settings.json to point to postgresql but it seems to have no effect. I have Postgresql installed and configured on a different machine and the storage folder is /ThingworxPostgresqlStorage. I can telnet port 5432 from Thingworx machine and I have run the scripts thingworxPostgresDBSetup.sh and thingworxPostgresSchemaSetup.sh and I can see the schema and all the tables created in Postgresql
  "PlatformSettingsConfig": {
    "BasicSettings": {
      "InternalAesCryptographicKeyLength": 128,
      "BackupStorage": "/opt/twxFoundationH2Trial-8.3.2/tomcat/apache-tomcat-8.5.23/ThingworxBackupStorage",
      "DatabaseLogRetentionPolicy": 7,
      "EnableBackup": true,
      "EnableHA": false,
      "EnableSystemLogging": true,
      "HTTPRequestHeaderMaxLength": 2000,
      "HTTPRequestParameterMaxLength": 2000,
      "Storage": "/opt/twxFoundationH2Trial-8.3.2/tomcat/apache-tomcat-8.5.23/ThingworxStorage"
    "AdministratorUserSettings": {
      "InitialPassword": "<password>"
  "PersistenceProviderPackageConfigs": {
    "PostgresPersistenceProviderPackage": {
      "ConnectionInformation": {
        "jdbcUrl": "jdbc:postgresql://10.6.0.33:5432/thingworx",
        "password": "<password>",
        "username": "twadmin"
Hi
you have installed the H2 version - so by default only H2 is used for the ThingWorx model:
The Postgresql can then only be configured inside the ThingWorx Composer as an additional Persistence Provider to store Streams / Value Stream / Data Tables.
All other data (including meta data) will be saved in the H2 database.
If you want to switch to a full Postgresql setup, you will need to export everything from the current system - install a new system based on Postgresql and import all the Entities into the new System.
But then I'm not sure if there's a Postgresql Trial version available for download.
I hope this clarifies the DB usages a bit more.
Cheers,
Michael
Hi
Cheers,
Michael
ahamad
6-Contributor
(To:mneumann)
Thanks Michael that clarifies it
