I've created an appKey, and tested that it passes browser authentication:
http://localhost:8080/Thingworx/Mashups?appKey=a0f4f7c7-de62-4bfb-bccf-ab7dea22c187 takes me to the listing of mashups without a prompt - which I would have seen without the appKey parameter on the URL.
I would like to launch my mashup:
This doesn't work. Is there a way to use an appKey to allow the mashup to know who I want logged in without being prompted?
Thank you, Andy
Hi Andy, this is actually something that you can find in the FAQ
http://localhost:8080/Thingworx/Mashups/YourMashupName?appKey=[YourKeyHere]&x-thingworx-session=true
So you need to make sure you create a session.
Thanks Pai
Keep in mind that your appKey is visible in that address bar now. That could be undesirable, depending on your application.
