Write to Kepware with RemoteKEPServerEXThing Template
tjason
1-Newbie
Hi All,
I can read the value from Kepware by using RemoteKEPServerExThing template.
But i dont know what is the correct way to write the value to Kepware in Mashup?
I also tried to write the value to Kepware from "My properties", the value is no update on Kepware
3 REPLIES 3
mattroy
(To:tjason)
Greetings,
If you are using the Simdemo project (loaded by KEPServerEX after install), Channel1_Device1_Tag1 should have a Base Type of INTEGER.  This may not be the problem, but I see you are using a STRING.  Once corrected, writes on the Property pages still need to be refreshed using the blue icon.  Remember to check the KEPServerEX Event Log for errors.
In the Mashup, add a Data Entity that points to GetProperties of the KEPServerEX (IOT_Kepware in your case) thing.  For a quick test, add a LED Display Widget and select Configure Bindings > Binding Sources then add Data1 as a binding.
Hope this helps.
tjason
1-Newbie
(To:mattroy)
Hi Matt Roy,
Thanks for your reply.
I already changed into integer but still not able to set it on the Property page.
For the step below, can i write value into Kepware? (I want to write to kepware)
Ascherer17
(To:tjason)
Did you ever get this figured out?  I'm having trouble writing to KEPServer tags as well.
