downloadLink on button click
mak1
I have created a service to create a file in repository.
I want to call the service on Button click to download the file, like DataExport widget does.
Is there any way to do that?
paic
(To:mak1)
Use the Service GetFileListingWithLinks for this functionality.
This will give you a hyperlink to allow the file to be downloaded.
If it has to look like a button (vs. the Link widget) you can always overlay the Link widget over the top of the Button.
mak1
(To:paic)
I have already used GetFileListingWithLinks in the Service and it returns downloadLink of the file, the downloadLink is set as SourceURL in the Link Widget, that scenario works perfectly.
But I want to call the Service when user clicks on a Button.
Situation: in my Mashup user sees charts and there is TimeSelector on the chart, I have to call the Service whenever user changes the TimeSelector. In this way a lot of unnecessary files are created. That's why I want to call the Service when user clicks on a Button.
paic
(To:mak1)
Great! Like I mentioned, you can use the Link Widget overlayed on a Button widget.
Use the TimeSelector Updated event to retrieve the proper link.
