Is there any way to change the colour of the button from green to red for displaying the start and stop of lines in the shop floor.
Hi Swetha, you can do that with the State based formatting see Style and State Definitions for more detail
Hi, yes you can do it with State Based formatting, but you should use ValueDisplay widget instead of a button, as button widget doesn't supports State Based Formatting.
