Hi All,
I've an service as:
If(Condtion)
//result should be infotable
else
//result should be an string
how can i achieve this, please help.
You can't.
Just make an infotable for both results, you can make an infotable which first column it's for instance baseType, and second column it's a String and Third column it's an Infotable, then based on baseType column use second or third column.
You can't.
