update second datatable value when the system time matches the row value of first datatable?
jshah-3
I have 2 datatable
first data table have 3 fields
start time ,Name and Stop Time
Second datatable have 2 datafields
Name and value(0/1)
now i require that when the system time (actual time) becomes equal to start time of first datatable the value becomes 1 for that name in the second datatable
and when the  system time (actual time) becomes equal to stop time of first datatable the value becomes 0 for that name in the second datatable
is it possible to achieve?
supandey
(To:jshah-3)
Hi Jugal it should be doable with a Timer thing which checks for actual time=start and you can subscribe to that event to execute service in the background to set the value = 1. And this same logic can be used for your 2nd question.
You can check for the Timer Thing Template for more detail
