while using windchill info*engine tasks to establish connection with thingworx i got the following error..?
mnalla
7-Bedrock
please convey your suggestions.
Error executing service
Wrapped com.ptc.jws.service.com.ptc.windchill.ws.Exception_Exception: com.infoengine.util.IEException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting; nested exception is: wt.util.WTException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Cause: com.infoengine.util.IEException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting; nested exception is: wt.util.WTException: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting Nested exception is: com.ptc.core.meta.common.InvalidTypeException: TypeModel only supports WCTypeIdentifiers. Unsupported value = WCTYPE|TrainingPracticeMeeting
regards,
madhu
posipova
20-Turquoise
(To:mnalla)
Please note that only Thingworx 7.3 is currently supported for windchill extension standalone/smart connected products bundle: http://support.ptc.com/WCMS/files/172294/en/WCTWXExtension.pdf
posipova
20-Turquoise
(To:mnalla)
What is your version of Thingworx platform, Windchill, tomcat, java?
Are there any errors in the windchill log?
mnalla
7-Bedrock
(To:posipova)
hi,
I am using thingworx 7.4, windchill 11.0 versions
posipova
20-Turquoise
(To:mnalla)
