The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Thingworx navigate: search by end item
Olivier_Jacob
What is the best way to search for an end item within a context/product?
Kind regards,
Olivier
I would create a global Saved Search (named END_ITEM_SEARCH) in Windchill with attribute "End Item" = YES in bottom part of Search panel. keep keyword empty it will use as input parameter for your search.
If end item is not available see https://www.ptc.com/en/support/article/cs231904
Afterwards in Navigate go in "Edit and Collection" and select "Saved Search" :
Kind regards.
2 REPLIES 2
Kind regards.
Olivier_Jacob
(To:schauvelin)
Hi @schauvelin ,
Thank you for your answer.
It works!
Kind regards,
Olivier
