When I put my email attribute to connect and test. I get an error: "There was an error while testing your identity Provider: The 'email' attribute mapping is incorrect."
Sometimes, it brings me to my company login page then this error occurs. Other times it goes directly to this error page.
Has anyone else had this issue?
Hi @Dylan12391 ,
Could you please confirm if the email attribute you are entering in the configuration is correct. You can review this in the metadata.xml or in the saml response. Also, please confirm if the email address you have used in the IdP is exactly same as the one in the CAC, meaning it is case sensitive. The chalk admin center stores email in all lowercase. Please let us know if you have any questions.
I am still seeing this error when trying to connect
Could you please send me a direct message with the below details:
Please review the below article to capture the SAML response:
