How to select model components in a 3d model without explicit definition of model Items?
- June 4, 2019
- 4 replies
- 3519 views
In Vuforia studio the best way to interact with 3d model components is to define explicit 3d modelitems (widget modelItem). So this will be an easy way to access the componets and to change their properties e.g. setting of the color
e.g.: $scope.setWidgetProp("modelItem-1", "color", "rgba(128,0,0,1)");
This will change the modelItem-1 property color to brown – and will display the component which is specified by this modelItem with a brown color.
Another way to do this in javaScript is something like :
$scope.view.wdg['modelItem-1']['color'] = "rgba(128,0,0, 1);";//brown $scope.view.wdg['modelItem-1']['opacity'] = 0.5;//set transparency to 0.5 //or for the same $scope.setWidgetProp("modelItem-1", "color", "rgba(128,0,0,1);"); //brown $scope.setWidgetProp("modelItem-1", "opacity", 0.5); //set transparency to 0.5
But in some cases during the project development it could be helpful when we are able to manipulate the components or request information about them without defining of explicit modelItem widgets. For example if we want to select a component to see some information about the component and change the color of it:
var PICK_COLOR = "rgba(255,0,0,1)"; ... $timeout( //timeout block 1 function() { //timeout function 1 angular.forEach( //==== for each 3d model block // this will call the function below for each 3d model $element.find('twx-dt-model'), function(value, key) { //for each 3d model block function //===================================================================================== angular.element(value).scope().$on('userpick',function(event,target,parent,edata) { // start the $on() listener 'userpick' + function definition //================================================================================= var pathid = JSON.parse(edata).occurrence; $scope.currentSelection = target + "-" + pathid; // create a component selection e.g. "model-1-/0/0/3/2" console.log("twx.app.isPreview() ="+twx.app.isPreview() ); //print an info if is called in preview mode and could be checked if required try{tml3dRenderer.setColor($scope.currentSelection, PICK_COLOR);} catch (ex) {console.warn("Exception 1 in tml3dRenderer.setColor()=>"+ex);} //will set the color of the selected component } //end of mobile device modelItemsList.push($scope.currentSelection); } //end is in array //================================================================================= }); // finish the $on() listener 'userpick' + function definition } //finish for each 3d model block function ); // finish for each 3d model block //================================================================================= } ,50); // finishtimeout block 1 and function
If we use PICK_COLOR = "rgba(255,0,0,0)";
It means that this color (red) is set for a selected component. Here the one additional detail is the last argument - which have a value of 0. Means alpha channel =0 - or full transparence. On the most mobile devices it will hide the selected component, but this is not supported techniques and we have to use always color with alpha channel >0. / transparent but still visible/
Calling of the tml3dRenderer.setColor(…, undefined); will set the component color back to default - example:
tml3dRenderer.setColor(‘model-1-/0/0/3/2’, undefined);
Another important point is that when we know the model name and know the component ids, in this case we can also set the color or hide components without explicit definition of model items.
For example for a particular model we have prepared a json file (*):
{ "/0/0/2" :"rgba(255,0,0,1);", "/0/0/0" :"rgba(128,0,0,1);", "/0/0/5" :"rgba(128,0,128,1);", "/0/0/3/0":"rgba(0,255,0,1);", "/0/0/6" :"rgba(255,200,0,1);", "/0/0/3/1":"rgba(0,0,0,0.2);", "/0/0/7/0":"rgba(0,0,0,0.2);", "/0/0/7/1":"rgba(0,0,0,0.2);" }
The model to which this json file was created is placed in Vuforia Studio as model widget with name=model-1
We can then read this json file (from prject->src\phone\resource\Uploaded folder) with some javaScript construct like (below) and set the color property of the components (also change the transparence - for the components with alpha channel =0.2)
Here an example (*):
//======================================================== // reading a json file with component setting for the components //======================================================== $scope.setCompProps=function() { var FILES_MODEL_COMP = { 'model-1':'comp_info.json' }; $scope.compJSON_Data = new Array(); angular.forEach(FILES_MODEL_COMP, function(jsonFile, target) { console.log("angular.forEach jsonFile = "+jsonFile + ", target="+target); $http.get('app/resources/Uploaded/' + jsonFile).success(function(data, status, headers, config) { $scope.compJSON_Data[target]=data; // in this case is $scope.compJSON_Data['model-1']= of the json structure file here the content'comp_info.json'; angular.forEach(data , function(color, path_id){ console.log("target="+target+" --> color = "+color + ",path_id="+path_id); tml3dRenderer.setColor(target+'-'+path_id, color); });//end for each function }) .error(function(data, status, headers, config) {console.log("calling in foreach 1 failed"); }); }); };
So when we start for this particular model the test code it will change the display of the model according to the setting of the comp_info.json file:
The code above is more than intended for setting colors and transparency . According a recommendation from development for hiding of components is better to use the hidden property:
tml3dRenderer.setProperties($scope.currentSelection, { hidden:true } );
The sample code below ( more simplified) is for the case that we want to blank a component by click on it:
angular.forEach($element.find('twx-dt-model'), function(value, key) {
// search all twx-td-model's -> means all model widgets
//for each model widget will set a userpick listener
try{
console.log('edata');console.warn(edata);
console.log("JSON.parse(edata)");console.warn(JSON.parse(edata));
console.log("=>>"+$scope.currentSelection);
} catch (ea) {console.error("not twx-model is clicked but still fired")}
try{
// here below the change recommended from R&D
} catch (e1234) {console.error( "e="+e1234); }
Here tested the code on the HoloLens 1.0 device:
When we have a color definiton with opacity -> the alpha channel set here e.g. to 0.1 / and the defined color should be changed later :
var PICK_COLOR_OPACITY1 = "rgba(,,,0.1)";
to change the rgba expression by setting another value of transparency you can use some construct like this:
var PICK_COLOR_OPACITY1 = "rgba(,,,0.1)"; var OPACITY_VAL=0.3; var PICK_COLOR_OPACITY2= PICK_COLOR_OPACITY1.replace( "0.1)",OPACITY_VAL+")");
The JavaScript code above will set transperancy value of 0.3 (replacing the 0.1 by 0.3)
But for the case that we have in a json file a defintion of color with alpha chanel =0 :
... "/0/0/3/1":"rgba(0,0,0,0.0);", ...
In this case we can modify (recommended) the code to check the value of the alpha channel and if it is ==0 to set the "hidden" property - example (*) :
//because R&D statement to use hidde property need to check of alpha chanel ==0
var start_alpha = color.lastIndexOf(",");
var end_alpha = color.lastIndexOf(")");
var alpha_str = color.substring(start_alpha+1, end_alpha);
var num = Number(alpha_str);
if ( (isNaN(num )) || (num <= 0.0) )
{//set color properly to alpha channel 1.0
var new_color= color.substring(0,start_alpha+1)+"1.0"+ color.substring(end_alpha,color.length)
tml3dRenderer.setColor(target+'-'+path_id, new_color);
tml3dRenderer.setProperties(target+'-'+path_id, { hidden:true } );
else
// color unchanged
The example above will set to the component the correct values of the color but with alpha channel 1.0 and will interpret the original alpha value from the file as setting of the hidden property to true. Does this make sense? Yes if we later set the hidden property to false then the color setting will be applied according to the definition from the json file
