Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We recommend using a3D Press Buttonin place of the3D Button, as the3D Buttonwidget will be deprecated in a future release.
A few things to keep in mind:
In May, the3D Buttonwidget will no longer available for new projects. This will not immediately affect existing projects that contain3D Buttonwidgets, and you will still be able to edit and re-publish projects that contain them.
In the future (TBD) all existing 3D Buttons will be transitioned to 3D Press Buttons. More information on this transition will be forthcoming.
Ability to pin and unpin 3D Audio and 3D Video widgets in runtime
German and Simplified Chinese now fully supported for HoloLens 2 voice commands
If your HoloLens was set to English when you installed Vuforia View, you'll need to delete it and reinstall after you've changed your language setting to Simplified Chinese or German
