You haven't set a status update. Log in and set your status.
There is a problem with this website’s security certificate. |
The security certificate presented by this website was issued for a different website's address.
You may have noticed that this forum has undergone a massive change, switching from one forum software (Jive) to another (Lithium). Unfortunately a lot of things still do not work as they are intended and we all hope that things clear up soon.
The mails you get are from the old system (Jive) where you don't have any access anymore (also other user have reported about unwanted mails from the old system).
The security alert you get is because PTC forgot to include subdomain www.ptcusercommunity.com in their new certificate.
you could try to delete the "www." from the address but then you will be redirected to the new domain community.ptc.com and I guess you see a "Page not found" error.
Hope that @Tmetcalf can help in those cases and turn off emails from old Jive.
I have opened a case with Jive to stop the email digest.
Best,
Toby
