Is it possible to create a WTDocument with MULTI_PRIMARY Content via JAVA API?
Hi @avillanueva
I found one example where MULTI_PRIMARY content type is used.
It it an EPMDocument and CADDS5 application(catia) during some migration/operation.
I don't know how it is used but I guess that it can not be used for WTDocument as a standard option to store two primary files...
PetrH
Hi @dullnigAlex,
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Furthermore, please consult this Community Search guideline as well, which boosts up your chances of finding a resolution to your topic(s) much faster, as well as articles on our Knowledge Base.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
You mean two files for primary content? I would think no. One file and rest go into secondary content.
Hi @avillanueva
PetrH
Hi @dullnigAlex
Generally primary content can be just one file.
It is primary/main file/ the only one 😄 .
PetrH
Hi @dullnigAlex,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
