API to do automatic publishing after checked in for DRW
BA_10670508
6-Contributor
Hi All,
In WC11 I am using - WorkInProgressHelper.service.checkin(obj, ""); API to checked in the drawing and after checked in automatically CAD Worker was getting published.
But In WC12 when I am using the same object is getting checked in but job is not getting triggered .
Could you please suggest me which API should I used to trigger Publish through code.
Thanks.
@HelesicPetr
3 REPLIES 3
HelesicPetr
(To:BA_10670508)
Hi @BA_10670508
There can be different configuration. Your wch 12 system do not contains configuration that allows publish automatically after check in..
I would check this first. If the publish job is done for normal checkin models.
PetrH
Hi @HelesicPetr ,
Yes when we are doing normal checkin through UI then publish job is working fine. But through code it is not working.
Thanks.
HelesicPetr
(To:BA_10670508)
@BA_10670508
Do you use publish rules?
If so there are several types of events. on checkin, on schedule, on unknown-source
If the rules do not contains unknow-source that is explanation why it does not work.
The check-in from custom code is the unknown-source
Check it
PetrH
