Ability to add action tool tip from action Validator code
SandipSharma1
7-Bedrock
As a user, the actions in the Windchill UI should have a tool tip message coming from the action validator class. The tool tip message can be used to communicate to the user why a particular action is disabled. Lot of time a user is not clear why a particular action is not enabled which may be because of multiple conditions being checked in the validator class.
0 REPLIES 0
