There are various API variations, such as POST, PATCH, and GET, for attachments in WTDocument within the REST APIs in WRS to perform operations on the document. My question is: Can we access the attachments in the drawing located in CADDocument through WTDocument? If so, can we replace the document there, such as a PDF file, with another file? If we can do this, how do we establish this connection?
Hi @ozclkonur,
Thank you for your question.
Best regards,
Hi @ozclkonur
If the REST API is designed for a WTDocument, then it is just for the WTDocument and can not accept different type as a EPMDOcument.
You should look to the EPMDocument REST API if there is something to manipulate with the attachments on the EPMDocument
PetrH
