Alias attribute between Change Objects
MV_10441462
Hi All
I want to map certain attributes from Change Request to Change Notice and from Change Notice to Change Activity. I created the alias attributes below mapping rules:
theChangeOrder2@wt.change2.AddressedBy2~theChangeRequest2^wt.change2.ChangeRequest2~name
theChangeActivity@wt.change2.IncludedIn2~theChangeOrder2^wt.change2.WTChangeOrder2~fgesArea
But I'm not able to find the attribute values migrated from one Change Object to another.
Can anybody help me understand my error here.
HI @MV_10441462
Do you try to set two aliases that one is pointing to a ChangeRequest name and second one to the first alias attribute from ChangeOrder
You can not do that.
If you want to use alias and point to the changeRequest name from Change activity you have to write full mapping
PetrH
HI @MV_10441462
PetrH
@HelesicPetr Thank you. Yes I was able to get the value from ChangeRequest and pass it on to ChangeTask directly by writing the full mapping.
The mapping theChangeActivity2@wt.change2.IncludedIn2~theChangeOrder2^wt.change2.WTChangeOrder2~child@wt.change2.ChangeProcessLink~parent^wt.change2.WTChangeRequest2~number- will pass on the value of number attribute from request to the attribute defined in the task.
For reference:https://www.ptc.com/en/support/article/CS106319
