Hmm bad bad.
try to use
PersistenceHelper.manager.refresh
// or
wt.fc.PersistenceHelper.manager.save
I guess that you do something wrong
PS. the save is the right one I guess.
PetrH
hi @smcvr
Something like how to use Persistable Manager?
PersistableAdapter obj = new PersistableAdapter ((wt.fc.Persistable)primaryBusinessObject,null,null,null);
obj.load("Reason_For_Change");
obj.set("Reason_For_Change","stringValue");
obj.apply();
wt.fc.PersistenceHelper.manager.modify((wt.fc.Persistable)primaryBusinessObject);
PetrH
Hi @HelesicPetr,
I tried the solution but the result did not change. I want to assign a value assigned to the n variable to SURFACE_M2 attributes.
I wrote it as in the code you sent.
obj.load("SURFACE_M2");
obj.set("SURFACE_M2","n");
obj.apply();
Hmm bad bad.
try to use
// or
PetrH
