Attribute Creation
Markh74
11-Garnet
Attribute Creation
Version: Windchill 12.1
Use Case: Good day I am a newbie and I am trying to create a new attribute under "Type and Attribute Management Utility" where it has multiple values in one line. For example, it must read XXX-XXXX-XXXX-XX-XX when I run a report and the input when creating a new part must have 5 blocks(fields) in a row separated by a dash. Please give suggestions.
Description:
Good day
Hello @Markh74,
Thank you for your question
Could you please share what you’ve tried so far and the outcomes?
Feel free to include any additional information that might be relevant and assist others in guiding you. Adding screenshots can also help us better understand what you’re trying to achieve.
Vivek N
Community Moderation Team.
HelesicPetr
(To:Markh74)
Hi @Markh74
You can try to use a constraint String format for your String attribute or Regular Expression
Attribute Constraint Rules
Constraints Tab
try String format syntax as CCC-CCCC-CCCC-CC-CC
or
Regular expression syntax as ...-....-....-..-..
PetrH
@Markh74
You gave a pattern of XXX-XXXX-XXXX-XX-XX
I have two questions:
  • Is X any uppercase alpha character or is this case insensitive?
  • Can X be a number?
Either way I'd use a regex constraint as @HelesicPetr has already mentioned.
FYI String Format constraint is a holdover from previous Windchill versions.  PTC recommends using Regex for new constraints.
