Batch file to execute a Java program when method server starts
smorla
11-Garnet
Hi
I have a utility program on Windchill - deployed and working.
I want this program to start running as soon as the method server starts and stops as soon as the method server stops.
Adding to the contents of this example, I added the following commands to run the java program right after windchill starts:
     cd C:\ptc\Windchill_11.0\Windchill
     java ext.mypackage.utilityClass
The error: "unable to find or load main class" appears.
However, running the command java ext.mypackage.utilityClass on Windchill shell directly works as it should.
So, why does the batch file fail to do the same?
TomU
(To:smorla)
You batch file is running in an environment that does not have all the same environment variables configured that exist when a Windchill shell is created.  See this:
Re: Rehosting Tool - Automate Extra Tasks
Starting in Windchill 11.0 PTC has created another bat file that can be called to configure the current shell environment just like a Windchill shell.  This means you could start your script, run this extra bat file, then continue with your custom code and it will behave just like you had started it from a Windchill shell.  See this for more info:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS230143
