eg. listener service should be called for any event occurring on wtpart or a different listener should be called for any event occurring on wtdocument
Yes you can..
You just need to implement the performStartupProcess() and in that method you can control which object type and event should be invoked.
eg.
protected void performStartupProcess() throws ManagerException
try
getManagerService().addEventListener(new ServiceEventListenerAdapter( this.getConceptualClassname() )
public void notifyVetoableEvent( Object event ) throws WTException,PropertyVetoException,WTPropertyVetoException
WorkInProgressServiceEvent persistenceEvent = (WorkInProgressServiceEvent)event;
//System.out.println("\n\n .performStartupProcess() starting for POST_CHECKIN..");
if( persistenceEvent.getEventTarget() instanceof WTPart)
Object object = persistenceEvent.getEventTarget();
//handleUploadEvent(object);
if(enablePostCheckIn.equalsIgnoreCase("true"))
handlePostCheckInEvent((WTPart)object);
},WorkInProgressServiceEvent.generateEventKey(WorkInProgressServiceEvent.POST_CHECKIN));
Thanks a lot Mahesh, il implement it and let you know the updates
