Can we show a Attribute having drop down values on Task page ?
vuchekar
Hi All,
My requirement is to show a custom Attribute on Analyse Change request Task page of change Request.
In this task, assignee can choose the correct values according to his choice from drop down values.
Any Idea ?
Vivek
BineshKumar1
(To:vuchekar)
This is possible by creating a resource file and  defining the resource file as the java class type for the variable. PTC has KB article on this https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS36017&art_lang=en&posno=1&q=workflow%20task%20dropdown&source…
The only challenge is keeping the value in sync with the enumerated list which you define in the type and attribute manager.
KD
(To:BineshKumar1)
Just to add few points.
  1. The resourcebundle file can be updated using enumCustomize.
  2. The solution mentioned in PTC article required Info Modeler.
kaushik
HelesicPetr
(To:KD)
Hi @KD
The InfoModeler is not needed if you use IDE to compile the java code with annotations for example Eclipse atc.
PetrH
