Version: Windchill 12.0
Use Case: All cases when I want to define quantity rule for components under assembly. This include using occurence or parameter/constraint.
Description:
Hello community,
According to About Publishing Associated Assigned Expressions, my understanding is that all expression should be exportable.
However, while testing, I am only able to find and validate REST services for extracting item/usage expression into XML file. Function to call out occurence expression information seems to be missing.
Additionally, I cannot find any information to extract parameter&constraint information neither.
I am very thankful if a pro can help confirm it or correct me with additional information. I am trying to include all material selection logics in XML and exchange with ERP, quantity logics will be missing with above restrictions.
Thank you very much.
Hi @JL_12625700
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
