My Creo version is 5.0, and windchill version is 11.0.
When I use IE as inner browser , It is working(yes, some dialogue show : some scripts make your browser running slowly, do you want to stop running them).
Are there some configurations in windchill server side not right?
Would anyone know how to fix this problem.
Thanks in advance!
Please check the PTC Article CS67489 for more details.
https://www.ptc.com/en/support/article/CS67489
This article may help to resolve the issue.
Thank you @Devidas(Devi) , now the problem is solved:
1.script running problem : need to change the inner browser type to Chrome,: need change the Creo options as your instruction;
2.Windchill reject Creo inner Chrome browser to visited: our server side security strategy problem: they limit access to the browser type ,version , and Os type etc.. they fixed this problem now .
