Hello everybody,
I have a problem with setting the document Type of a new created Document from a expression Robot Workflow. I managed to create a WTDocument but cant set the subtype type.
I found this article, but could not get it to work: https://community.ptc.com/t5/Windchill/How-to-create-subtype-of-WTDocument-by-API/td-p/482345
Thank you for your help.
String name = "Test1234566788"; // Name
String number = "12343455677"; // Number
String lifeCycleName = "LC_TEST"; // Lifecycle name
String container_path = "/wt.inf.container.OrgContainer=Test/wt.inf.library.WTLibrary=Test"; // The container where the document will be created/located
String folder_path = "/Default"; // Folder path
wt.doc.WTDocument doc = wt.doc.WTDocument.newWTDocument();
doc.setName(name);
doc.setNumber(number);
/// ----------- TESTAREA -------------------------------
doc.setDocType(wt.doc.DocumentType.toDocumentType("WCTYPE|wt.doc.WTDocument|de.test.TESTDocument"));
wt.inf.container.WTContainerRef containerRef = wt.inf.container.WTContainerHelper.service.getByPath(container_path);
doc.setContainerReference(containerRef);
wt.folder.Folder folder = wt.folder.FolderHelper.service.getFolder(folder_path,containerRef);
wt.folder.FolderHelper.assignLocation(doc, folder);
wt.lifecycle.LifeCycleTemplate lct = wt.lifecycle.LifeCycleHelper.service.getLifeCycleTemplate(lifeCycleName , doc.getContainerReference());
doc = (wt.doc.WTDocument) wt.lifecycle.LifeCycleHelper.setLifeCycle(doc, lct);
doc = (wt.doc.WTDocument) wt.fc.PersistenceHelper.manager.store(doc);
hi It does not work this way
you need to use different API
document.setTypeDefinitionReference(TypedUtilityServiceHelper.service.getTypeDefinitionReference("wt.doc.WTDocument|com.myDocType"));
Thank you for your fast reply. I'm getting the following error:
WfExpression_10773332627.java:45: error: package TypedUtilityServiceHelper does not exist
Windchill Version is 11.1 M020 CPS17
I have to add wt.type. before TypedUtilityServiceHelper Class
document.setTypeDefinitionReference(wt.type.TypedUtilityServiceHelper.service.getTypeDefinitionReference("wt.doc.WTDocument|com.myDocType"));
But now I get the following Exception:
wt.workflow.engine.FailedExpressionException: wt.util.WTException: The value of "Type Definition Reference" cannot be set to null, since it is a "required" attribute.
Hi @YannickM
The string "wt.doc.WTDocument|com.myDocType" is full definition of Subtype WTDocument object so the subtype has to exist in type and attribute management.
go there and check what string definition is yours WTDocument subtype and use it.
The string has to contains full definition same as my example. The separator is |
Main type
plus subtype
Hope this can help.
PetrH
Thank yóu very much. I found my mistake. I had a sub-subtype of Document. So in your example a subtype of "My Doc Type". I only included the internal Name of the "Document" and my Subtype. So now I tried it with including the whole path and it works:
wt.doc.WTDocument|com.myDocType|com.myDocType.mySubDocType
Hi @YannickM
That's right if you use more levels you need to specify full path to subtype.
I'm glad that it works.
PetrH
