Creating a file under product with Workflow
smcvr
I want a file to be created in the product when the user starts the workflow process. I prepared a code for this, but I could not proceed further because I received an error in the expression.
How can I perform such an operation in the workflow?
What are the errors in my code?
CODE:
try {
    wt.org.WTPrincipal wtPrincipal = wt.session.SessionHelper.manager.getPrincipal();
    wt.org.WTPrincipalReference principalReference = wt.org.WTPrincipalReference.newWTPrincipalReference(wtPrincipal);
    // Assuming productId is defined somewhere in your code
    wt.folder.Folder productFolder = wt.folder.Folder.newFolder();
    productFolder = wt.pdmlink.PDMLinkProduct(productId);
    wt.folder.Folder newFolder = wt.folder.Folder.create();
    newFolder.setName(name);
    newFolder.setDescription(folderDescription);
    wt.folder.FolderHelper.service.addToFolder(productFolder, newFolder);
    wt.fc.PersistenceHelper.manager.save(newFolder);
    System.out.println("Folder created successfully under the product.");
} catch (Exception e) {
    e.printStackTrace();
wt.inf.container.WTContainerRef containerRef = getContainerRefById(productId);
wt.query.QuerySpec querySpec = new wt.query.QuerySpec(wt.folder.Folder.class);
querySpec.appendSearchCondition(
    new wt.query.SearchCondition(
        wt.folder.Folder.class,
        wt.folder.Folder.CONTAINER_REFERENCE + "." + wt.inf.container.WTContainerRef.KEY + "." + wt.inf.container.WTContainerRef.ID,
        wt.query.SearchCondition.EQUAL,
        containerRef.getId()
    new int[]{0}
wt.fc.QueryResult queryResult = wt.fc.PersistenceHelper.manager.find(querySpec);
queryResult.nextElement();
wt.inf.container.WTContainerRef containerRef = wt.inf.container.WTContainerRef.newWTContainerRef(containerId);
Note: I defined the productId ande containerId value as a string and added Id.
ERROR:
Checking Syntax...
WfExpression_2287132672.java:97: error: cannot find symbol
  symbol:   method newFolder()
WfExpression_2287132672.java:98: error: cannot find symbol
  symbol:   class pdmlink
WfExpression_2287132672.java:100: error: cannot find symbol
  symbol:   method create()
WfExpression_2287132672.java:101: error: cannot find symbol
  symbol:   method setName(String)
WfExpression_2287132672.java:102: error: cannot find symbol
  symbol:   variable folderDescription
WfExpression_2287132672.java:104: error: cannot find symbol
  symbol:   method addToFolder(Folder,Folder)
WfExpression_2287132672.java:111: error: cannot find symbol
  symbol:   method getContainerRefById(String)
WfExpression_2287132672.java:116: error: cannot find symbol
Syntax check complete.
Fadel
23-Emerald I
(To:smcvr)
can you try with class wt.folder.SubFolder
Fede
Fadel
23-Emerald I
(To:smcvr)
Fede
smcvr
(To:Fadel)
Hi @Fadel ,
Thank You for help 🙂
