Customizations using com.thoughtworks.xstream, javax.ws.rs and javax.servlet
ocorten-2
We are upgrading from Windchill PDMLink 12.0.2.17 ro 13.0.2.0 and during the compilation of our Java customizations we get these errors:
com.thoughtworks.xstream does not exist
XStream library dependencies removed in Windchill 12.1+
See: https://www.ptc.com/en/support/article/CS386935
javax.ws.rs does not exist:
Running: windchill wt.util.jmx.Which javax/ws/rs/core
  • WC12 - URL: jar:file:/has/fs01/opt/ptc/windchill/codebase/WEB-INF/lib/wc3rdpartylibs.jar!/javax/ws/rs/core
  • WC13 - Resource not found
javax.servlet does not exist:
Running: windchill wt.util.jmx.Which javax/servlet
  • WC12 - URL: jar:file:/has/fs01/opt/ptc/windchill/codebase/WEB-INF/lib/ie3rdpartylibs.jar!/javax/servlet/
    and
    URL: jar:file:/has/fs01/opt/ptc/windchill/lib/servlet.jar!/javax/servlet
Has anyone else stumbled upon this and was able to fix it?
HelesicPetr
(To:ocorten-2)
Hi @ocorten-2
Yes,
take the old library from the old system separate the classes that are needed by your app from there and add it to new system.
I did it many times if some methods classes where removed from the system but they were useful for me.
PetrH
HelesicPetr
(To:ocorten-2)
Hi @ocorten-2
Yes,
PetrH
Thanks a lot. Sounds like a quick (and dirty) solution.
It will give us time to rewrite the code to use other libraries.
HelesicPetr
(To:ocorten-2)
Hi @ocorten-2
The clear way is "do not use it" 😄 I know it is also wrong way 😄
PetrH
