How to make one attribute have its values driven by another attribute on the object's Create Wizard
Nandha
7-Bedrock
I followed the instructions in the below-mentioned article but I'm unable to get work on this
 Article Number: CS144852
Article - CS144852 - How to make one attribute have its values driven by another attribute on the object's Create Wizard in Windchill PDMLink (ptc.com)
This requirement can be met via the cascading attribute, but we need this functionality through customization.
I also refer one community post.
Solved: Re: Adding javascript validation using DataUtiliti... - PTC Community
The java script & data utility is not working.
 Kindly help us on this requirement for Windchill 12.0 & 12.1
6 REPLIES 6
Nandha
7-Bedrock
(To:Nandha)
For Windchill Version; 12.0, 12.1
What are you trying to accomplish?
No, I mean your business purpose. I understand you're trying to use the info in that article, but there may be other ways to accomplish the business purpose, if you share the business objective.
Our client has 3 to 4   Attributes based upon the given values; other attributes should filter and show the value (While creating the objects) This can be achieved through cascading, but we need to go for customization.
If you have any other ways to achieve this, please let us know.
Catalina
Moderator
(To:Nandha)
Hi @Nandha,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
