Why is DeletedParts options are available in ESI Response file? Does it get enabled in any way or is it just a place holder ?
<DeletedParts NAME="DeletedParts" TYPE="Unknown" STATUS="0">
</DeletedParts>
Sha
The deletedparts header is always empty and there’s no options to enable it.
If a part version has been published with ESI successfully, the referential integrity rule does not allow it to be deleted.
When parts are deleted from a structure, those changes should show up in the deletedBoMComponents header.
