Disable or hide the create PDF action for documents which was enabled by DefaultUIComponentValidator
Akash.S_121
Version: Windchill 12.0
Use Case: user need not see the action of createPDF for WtDocuments which are inside one specific folder. user did not able to perform the action. that action was enabled by DefaultUIComponentValidator.
Description:
one of the subfolders, we used for storing all approved documents and Restricted documents. if this action enabled, it allows all users to recreate the PDF without stamps that may cause data changes that to for wt documents.
i already created validator but it is not working. i cannot be able to see the logs in method server.
Here is the class example:
private UIValidationResultSet validateMenuEntry(UIValidationKey vkey, UIValidationCriteria vcriteria, Locale locale) throws WTException {
UIValidationResultSet vrs = UIValidationResultSet.newInstance();
WTReference wref = vcriteria.getPageObject();
Persistable object = wref.getObject();
log.debug("Validating menu entry for object: " + object);
if (object instanceof EPMDocument) {
System.out.println("object is EPM Document");
EPMDocument doc = (EPMDocument) object;
if (doc.getDocType().toString().equalsIgnoreCase(CADDRAWING)) {
System.out.println("object is : : " + doc.getDocType().toString());
vrs.addResult(UIValidationResult.newInstance(vkey, UIValidationStatus.ENABLED));
System.out.println("object is EPM Document-- CreatePDF action was enabled");
} else if (object instanceof WTDocument) {
WTDocument doc = (WTDocument) object;
String typeID = TypedUtility.getTypeIdentifier(doc).getTypename();
String containerName = doc.getContainer().getName();
System.out.println("object is ::" + typeID + " , " +containerName);
vrs.addResult(UIValidationResult.newInstance(vkey, UIValidationStatus.DISABLED));
log.debug("Document type: " + typeID);
log.debug("Container name: " + containerName);
if ((typeID.equals(EXTERNAL_DOC_TYPE) || INTERNAL_DOC_TYPE.equals(typeID))
&& (GLOBAL_STD_LB.equals(containerName) || BRAKING_ACTUATION.equals(containerName))) {
boolean isLicenseType = ZFPLMObjectHelper.getBooleanAttributeValue(doc, LICENSE_TYPE);
String folderLocation = FolderHelper.getLocation((CabinetBased) doc);
System.out.println("License and folder location is ::" + isLicenseType + " , " +folderLocation);
log.debug("License type: " + isLicenseType);
log.debug("Folder location: " + folderLocation);
if (isLicenseType || RESTRICTED_ACCESS_FOLDER.equals(folderLocation)) {
vrs.addResult(UIValidationResult.newInstance(vkey, UIValidationStatus.HIDDEN));
return vrs;
// Additional check for "Documents with Restricted Access" folder
System.out.println("folderlocation is : " + folderLocation);
if (RESTRICTED_ACCESS_FOLDER.equalsIgnoreCase(folderLocation)) {
System.out.println("Document is in 'Documents with Restricted Access' folder. Disabling action.");
log.debug("Document is in 'Documents with Restricted Access' folder. Disabling action.");
return vrs;
if (ProceedJobHelper.isAllowedFormat(doc.getFormatName())) {
System.out.println("Proceed Menu Entry is ended...");
return vrs;
HelesicPetr
(To:Akash.S_121)
Hi @Akash.S_121
Can you share some screen shot of your action in the menu? With jcadebug enabled?
I would recommend to use &jcaDebug=1 to check if the filter is really defined for the action.
If the filter is not configured properly, you need to check all miss spelling in your definition.
in the actionModel definition if the name of your filter is same as the definition in the service.properties
and if the service properties contains correct class, and the class is in right location in the folder structure of the server.
If you are sure that it should work, there is some mistake in your general definition.
check all definition step by step, and check all miss spelling possibilities.
PetrH
HelesicPetr
(To:Akash.S_121)
Hello @Akash.S_121
Do you have a question? or you just share a tip how to use validator for an action menu?
Help Center - Defining a New Action
Help Center - Implementing Validation Filters
PetrH
I do not know, why the above validator class is not calling. something i did wrong.
service.properties file updated and custom-actions.xml also updated and custom.xconf also updated.
why still this class is not called on UI. something i missed? is there any ways?
HelesicPetr
(To:Akash.S_121)
Hi @Akash.S_121
PetrH
Thank you @HelesicPetr ,
i did all things correct, but i mistyped the validator class location in xconf file that's why this validator is not calling.
now i resolved the issue.
thank you for your points and articles.
