Dears,
I have customized two attributes in the part subtype which have a cascading relationship, attribute A has roughly 70 values, attribute B has roughly 1000 values, attribute A is level1, attribute B is level2, attribute A is one-to-many for attribute B. I am considering if there is a performance issue if I create 70 rules in cascading? If there is a performance issue, is there any other suitable way to handle such attributes? Thanks
BR,
Chason
you may have performance issues in the create new wizard loading time ,but generally starting 3000 cascading rules
Issue is due to client need to handle a huge response from server, there is no database or code improvement.
You will have to review with business to decrease number of rules.
