Download created file on Client UI from any location
Version: Windchill 12.1
Use Case: I have one action on Details page action set of part and on click of that action I am creating one excel file with few custom data in windchill temp location. Now requirement is it should get downloaded on client UI on click of that custom action. So need help with line of code to download created file from particular location.
Description:
FormResult result = new FormResult();
String filePath = "file path";
File file = new File(filePath);
URL localURL = NmObjectHelper.constructOutputURL(file, file.getName());
result.setForcedUrl(localURL.toString());
result.setURL(localURL.toString());
FeedbackMessage msg = new FeedbackMessage(FeedbackType.SUCCESS, Locale.CHINA, "Export Data", null, "Export Success");
result.addFeedbackMessage(msg);
result.setStatus(FormProcessingStatus.SUCCESS);
return result;
Emeritus
Hello @VK_11755221,
It looks like you have a response from a community member. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
