Version: Windchill 12.0
Use Case: Start an advanced classification search - Open Advanced Search page - Under Type, select a classification type. - Under Classification field, specify a classification node (a classification binding attribute) - Now the Criteria options updates and all corresponding classification attributes are available as Criteria conditions
Description:
Please do the steps described in the Use Case.
What I want to achieve here at this point is to exclude/remove a specific classification attribute so that the user cannot add it as a Criteria condition.
How can I do that in Windchill? Is that possible at all?
Thank you in advance!
Hi @CS_10918708 and thanks for your first post.
I am replying here to move your topic up in the line and get attention.
