is there any API to change FamilyTable name
SA_9497989
7-Bedrock
I want to change familytable name through code is there any API ?
I have tried the following API, but getting following exception
IdentityHelper.service.changeIdentity();
A persistence error has occurred. System message follows:
2024-06-04 13:28:48,055 INFO [RMI TCP Connection(17)-192.168.170.106] wt.system.err wcadmin - Nested exception is: (wt.epm.util.EPMResource/364) wt.util.WTException : Family table validation failed. Unless this error occurred while importing a package, contact PTC. Failure to import a package may be due to a compatible generic part not being available during import.
Similar discussion - "Windchill Api to update Family table attribute": https://community.ptc.com/t5/Windchill/windchill-Api-to-update-Family-table-attribute/td-p/892235
