File Based Series
DKWc
File Based Series
Hi All,
Trying to create a new file based series to be used for objects.
Steps followed:
created xml with series name and values.
loaded using windchill wt.series.LoadFileBasedSeries Ax_FileBase.xml -load in shell.
added series name in <Windchill>\codebase\wt\series\SeriesRangeSelectorRB.RB.ser using enumcustomize
run ant -f codebase/MakeJar.xml
added series name in wt.properties file wt.series.HarvardSeries.seriesNames=MilSpec,Arx_FileBase
added series name in OIR <Arg>wt.series.HarvardSeries.Arx_FileBase</Arg>
Still it not fetching the new file based series.
Anything in correct I'm doing.
HelesicPetr
(To:DKWc)
HI @DKWc
What the ser file id if for? Are you trying to add something different seed name then MILST or NUMBERIC ?
I am not sure if you can do it.
Series name is added directly in the XML file
here is example of State-based Scheme
oir example
<!-- set the version info to a generated version info -->
<AttrValue id="MBA|versionInfo" algorithm="com.ptc.core.foundation.vc.server.impl.VersionInfoGenerator">
     <Arg>wt.series.HarvardSeries.StateBased1X</Arg>
</AttrValue>
One important advice, do not never rewrite existing series names and OOTB schema.
Every-time use own name StateBased1X and so on. >D
the OOTB xml file can be found in "C:\Windchill_12.0\Windchill\loadFiles\pdmlink\StateBasedVersioning.xml"
last point, check all typo mistakes in your naming. xml file, OIR rule and so on.
PetrH
DKWc
(To:HelesicPetr)
Thanks a lot for the reply.
Its working now. Did some unnecessary steps.
avillanueva
23-Emerald I
(To:DKWc)
If you could, post a summary of the fix and then mark which post was the solution (Pete's or you figured it out on your own).
