Hello all, Is there any way to get active promotion requests on a part/document?
dbharade
Given a specific part, we would like to get linked promotion request and/or change notice that is still active.
3 REPLIES 3
BineshKumar1
(To:dbharade)
For changes, I used - http://support.ptc.com/cs/wncdoc/102/wcapi/wt/change2/ChangeService2.html#getLatestChangeRequest(wt.change2.ChangeableIf…
there are similar methods for changeissue and changeorder in ChangeHelper2
For promotions, I used WTCollection pNotices =  MaturityHelper.service.getPromotionNotices(wCollect); wCollect is a part collection
Hi ,
For to get active Promotion Notice from Affected object we can use following logic
              WTObject returnObj = null;
       wt.maturity.StandardMaturityService p=new wt.maturity.StandardMaturityService();
       WTArrayList arr=new WTArrayList();
       arr.add(wtPart);
       WTCollection pn1=p.getPromotionNotices(arr);
       PromotionNotice not=null;
       if(!(pn1.isEmpty()))
              for (Object nott: pn1)
                     ObjectReference or=(ObjectReference) nott;
                     Persistable per=or.getObject();
                     if(per instanceof PromotionNotice)
                           not=(PromotionNotice) per;
                           System.out.println("Notices"+not);
                           LifeCycleState state=not.getState();
                           String s=state.toString();
                           if(s.equalsIgnoreCase("UNDERREVIEW") )
                                  returnObj = not;
       return returnObj;
Similarly if we want Change Notice from WTPart/WTDocument directly do you know any API?
VladiSlav
(To:hpali)
hpali, thank you for the code provided. It worked for us
