Hello everyone, please tell me how to add an action to the "Actions" button for only one subtype of the document WTDocument?
Hi
You may check for the property menufor described here :
focus on the "menufor" keyword this point.
Just be aware of the article : CS312920 if this not work, a pre-validation is required.
Hi
Hi VladiSlav, did this work for you?? i tried the same for one of the document subtype dint work, so need your suggestion
