Hello everyone, please tell me how to upload a file to WTDocument using Info*Engine?
Or how to use java to create a document and upload a file to it?
Here is a existing article https://www.ptc.com/en/support/article/CS18364.
Please check if it is works for you.
Cassie
Cassie
cyang-5, thank you very much for your response, this is what you need.
Please tell me, do You have an example of how to get files from WTDocument, which is located in Windchill?
HI Vadsilav,
Please take a look in this article :
https://www.ptc.com/en/support/article?n=CS18364
Where you will be to create a document a upload a primary content.
Note that you may have to upload first content into server.
Note also that it is a server side API. it is only working by invoking methodServer like described in this article :
Hope this will help
Hicham
Using SOAP you
hlafkir,thank you very much for your help, I had a problem, the document is being created, but the file is not attached, an error is issued:
(wt.pom.pomResource/0) wt.pom.POMInitException: A persistence error occurred. System message follows:
Nested exception is: wt.method.MethodServerException: No active method context
at wt.method.MethodContext.getContext(MethodContext.java:1835)
at wt.pom.PersistentObjectManager.getPom(PersistentObjectManager.java:268)
at wt.pom.Transaction._start(Transaction.java:690)
at wt.pom.Transaction.start(Transaction.java:654)
at com.acme.test.excel.TxtToExcel.createAndUpload(TxtToExcel.java:65)
at com.acme.test.excel.TxtToExcel.main(TxtToExcel.java:43)
Process finished with exit code 0
Hi Vadislav,
Did you implement the rmi invocation ? How did you do that ? and where is located your primary content ?
something like this :
public class CreateDoc implements RemoteAccess {
public static void main(String[] args)
// Retrieve a MethodServer remote reference
// from the ServerManager
RemoteMethodServer rms = RemoteMethodServer.getDefault();
// Authenticate using the default
// HTTPLogin Authenticator
rms.setUserName("wcadmin");
rms.setPassword("ts");
try
rms.invoke("CreateDocument",
"ext.CreateDoc", null, null, null);
System.out.println("Should have worked, check the MS log");
catch (Exception e)
e.printStackTrace();
public static void CreateDocument() throws WTException, SQLException, PropertyVetoException, IOException {
Hicham
package com.acme.test.excel;
import org.apache.poi.hssf.usermodel.HSSFWorkbook;
import org.apache.poi.ss.usermodel.Sheet;
import org.apache.poi.ss.usermodel.Workbook;
import wt.content.ApplicationData;
import wt.content.ContentRoleType;
import wt.content.ContentServerHelper;
import wt.doc.DocumentType;
import wt.doc.WTDocument;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.folder.Folder;
import wt.folder.FolderEntry;
import wt.folder.FolderHelper;
import wt.inf.container.WTContainer;
import wt.inf.container.WTContainerHelper;
import wt.inf.container.WTContainerRef;
import wt.method.RemoteAccess;
import wt.pom.Transaction;
import wt.util.WTException;
import wt.util.WTInvalidParameterException;
import java.beans.PropertyVetoException;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
public class TxtToExcel implements RemoteAccess {
public static void main(String[] args) throws IOException, WTException, PropertyVetoException {
Workbook wb = new HSSFWorkbook();
Sheet sheet0 = wb.createSheet("Tester");
Sheet sheet1 = wb.createSheet("911");
Sheet sheet2 = wb.createSheet("Tester911");
FileOutputStream fos = new FileOutputStream("Excel/123.xls");
wb.write(fos);
fos.close();
String container_path = "/wt.inf.container.OrgContainer=TESTER911/wt.pdmlink.PDMLinkProduct=Тестовое изделие";
WTContainerRef containerRef = WTContainerHelper.service.getByPath(container_path);
Folder folder = FolderHelper.service.getFolder("/Default/"+"Excel", containerRef);
createAndUpload("excelmvm", "excelmvm", containerRef, folder);
static void createAndUpload(String name, String number, WTContainerRef product, Folder folder)
throws WTInvalidParameterException, WTException, PropertyVetoException, IOException {
Transaction tx = new Transaction();
try{
WTDocument doc = WTDocument.newWTDocument(name, number, DocumentType.getDocumentTypeDefault());
doc.setContainerReference(product);
doc.setDomainRef(((WTContainer) product.getObject()).getDefaultDomainReference());
FolderHelper.assignLocation((FolderEntry)doc, (Folder)folder);
// WTDoc needs to be stored before content may be added
doc = (WTDocument)PersistenceHelper.manager.store(doc);
ApplicationData theContent = ApplicationData.newApplicationData(doc);
String filename = "test.txt";
File theFile = new File("D:\\ptc\\Windchill_11.1\\eclipse\\Excel\\123.txt");
theContent.setFileName(filename);
theContent.setRole(ContentRoleType.toContentRoleType("PRIMARY"));
theContent.setFileSize(theFile.length());
FileInputStream fis = new FileInputStream(theFile);
tx.start();
theContent = ContentServerHelper.service.updateContent(doc, theContent, fis);
ContentServerHelper.service.updateHolderFormat(doc);
tx.commit();
doc = (WTDocument) PersistenceHelper.manager.refresh((Persistable) doc, true, true);
fis.close();
}catch(Exception e) {
tx.rollback();
HI Vadislav,
In my first post, I provided two same article. Sorry for that.
The RMI implemntation is here :
https://www.ptc.com/en/support/article/CS24105
without that, you will always get the error you're facing..
As said earlier, pleas eimplement your code like this :
try
catch (Exception e)
hlafkir,I repeated the example https://www.ptc.com/en/support/article/CS24105 , but I get errors:
wt.util.WTRemoteException: Unable to invoke remote method; nested exception is:
java.lang.ClassNotFoundException: com.acme.test.excel.ServerClass
at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at wt.method.MethodServerImpl.getTargetClass(MethodServerImpl.java:451)
at wt.method.MethodServerImpl.invoke(MethodServerImpl.java:374)
import wt.method.RemoteMethodServer;
public class TxtToExcel {
public static void main(String[] args) {
rms.setPassword("wcadmin");
try {
rms.invoke("doSomethingInMS",
"com.acme.test.excel.ServerClass", null,
new Class[]{String.class},
new Object[]{"TxtToExcel"});
} catch (Exception e) {
public class ServerClass implements RemoteAccess {
public static void doSomethingInMS(String msg)
System.out.println("Hello World from "+ msg +" in MS !!");
Please try this simple invocation :
package ext;
import java.sql.SQLException;
try
catch (Exception e)
try {
tx.start();
WTDocument epm = WTDocument.newWTDocument("MyName1", "MyNumber1", DocumentType.getDocumentTypeDefault());
WTContainerRef container_ref = WTContainerHelper.service.getByPath("/wt.inf.container.OrgContainer=Demo Organization/wt.pdmlink.PDMLinkProduct=Drive System");
Folder folder = FolderHelper.service.getFolder("/Default",container_ref);
WTContainerHelper.setContainer(epm, container_ref);
FolderHelper.assignLocation((FolderEntry) epm, folder);
PersistenceHelper.manager.save(epm);
ApplicationData theContent = ApplicationData.newApplicationData(epm);
File theFile=new File("C:\\test.txt");
theContent.setUploadedFromPath(theFile.getPath());
FileInputStream fis = new FileInputStream (theFile);
theContent = ContentServerHelper.service.updateContent(epm, theContent, fis);
ContentServerHelper.service.updateHolderFormat(epm);
epm = (WTDocument) PersistenceHelper.manager.refresh((Persistable)epm, true, true);
fis.close();
tx.commit();
tx = null;
catch (Exception e)
finally
if(tx!=null)
tx.rollback();
