The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
Hello!
Anyone who knows to to bulk retrieve attribute values?
To bulk load lots of attribute values from a single persistable you would normally write something like below:
PersistableAdapter pa = new PersistableAdapter(p,null,Locale.US,null);
pa.load(attributeNames);
for(String attributeName : attributeNames){
String attributeValue = (String) pa.get(attributeName);
However this only allows me to fetch attribute values for a single persistable at a time.
I'm looking at a way to extend the code to bulk load a collection of persistables instead.
Does anyone know if this is possible?
Doing this by querying the database is quite easy but I would much rather use an existing API.
Thanks and best regards,
Peter
I don't think PersistableAdapter has any constructor to take collection of objects. You can either write a QuerySpec to fetch all object and loop one by one to get the required attributes Or try using Info*Engine Webject to query objects with attributes.
Bhushan
