Can anyone help to create windchill product through API. thanks in advance
Hi @nimish ,
Did you try using below example?
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Get-Properties" type="MGT">
<ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
<ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])" />
<ie:param name="TYPE" data="wt.inf.container.WTContainer"/>
<ie:param name="ATTRIBUTE" data="name" />
<ie:param name="WHERE" data="name='Demo Organization'" />
<ie:param name="GROUP_OUT" data="container" />
</ie:webject>
<ie:param name="instance" data="${properties[]wt.federation.ie.VMName[]}"/>
<ie:param name="attribute" data="*"/>
<ie:param name="type" data="wt.inf.template.DefaultWTContainerTemplate"/>
<ie:param name="where" data="name='${@FORM[]template[]}'" default="General Product"/>
<ie:param name="group_out" data="template"/>
</ie:webject>
<ie:webject name="Create-Objects" type="ACT">
<ie:param name="CONTAINER_REF" data="$(container[]obid[])"/>
<ie:param name="FIELD" data="containerInfoName='Product Test4'"/>
<ie:param name="field" data="containerInfoNumber='Product Test4'"/>
<ie:param name="field" data="template=${template[]masterReference[]}"/>
<ie:param name="FIELD" data="privateAccess=false"/>
<ie:param name="TYPE" data="wt.pdmlink.PDMLinkProduct"/>
<ie:param name="ATTRIBUTE" data="name, obid" delim=","/>
<ie:param name="GROUP_OUT" data="$(@FORM[]group_out[])" default="product" />
</ie:webject>
Note: Modify highlighted fields accordingly.
Best Regards,
Shirish
Thanks Shirish for the reply I will try it.
