I am using the Decode Datebase Function to return a datetime when a task has a status of "Completed".
It looks like this:
However, when I use the above approach the return type is string and not a timestamp.
The reason I want a timestamp for this value is so the user can set the criteria/param before generating the report easily by selecting a date from the calendar picker (like in the image below) instead of entering free text.
Hi @mariaSutton
If you use Datebase Function the return value is always string,
You would need to retype the output as you has asked, but I am not sure you can do that in the Reporting Management (QueryBuilder).
PetrH
Why do you need to use the database function? Can't you get the timestamp directly from a "Reportable Item"?
